Not terribly happy, really. 52141 miles, 7 years old, 60k service carried out, and this is the list:
Right rear wheel studs need replacing - will have to be a DIY repair I think.
Front left brake caliper - one piston sticking. Whole unit replaced 2 years ago .... will get a refurb kit and sort it myself
Transfer case output seal leaking - was replaced 2 years ago as well. Again, I suspect I can do this myself
Front left shock weeping - have sent a mail to Oz for their thoughts - but probably need to replace fairly soonish. Wonder if they can be re-built?
ATF needs replaced - WTF - it's meant to last for 100,000 miles - how do the figure that one out??
Front brake disks corroded and need replaced at next pad replacement
I'm surprised the fancy ToughDog shock is leaking at 2 years and not a heck of a lot of miles. And some monkey has over-tightened some wheel nuts along the way somewhere.
But I guess it's mostly corrosion-related - Scottish salty roads doing their bit to lighten my wallet
Oh yes - total cost including MOT was just over £400
I've only done just about 5100 miles in a year, so that's fairly extreme
Bugger.
