Just returned home after leaving my 50th aniversary parked up for 6 months and the height control off light came on. Checked and found it had dumped the fluid from either the pipe that goes into nitrogen tank mounted on chassis or the tank itself. How do you undo the pipe and get the tank off ? Access to the bottom two bolts holding the tank is easy but can't see how to access the two above.
Any help would be much appreciated.
Rich
Rich
