After struggling to get up the small rock steps I stopped and dropped all the tyres down from 35psi to 20psi. This meant the 12.5" wide tyres were now a few inches wider, giving me a nice big 14-15" wide foot print in the snow.![]()
While packing my workshop up today I came across the damaged front ARB locker.
I intend on going to their head office in Melbourne with the damaged locker. I will explain to them that both the front and rear lockers have been fitted exactly to their instructions and both times the pinion has then hit the ARB locker causing damage.
I do not like the idea of grinding the pinion teeth. Once the teeth on the pinion are machined, they are case hardened. If you then grind away part of the tooth, you destroy that area of the case hardening
Hi Vergarwi,
Thanks.
I could have bought another 70 here in the UK and swapped everything over, but.........................
Almost all the 70's for sale in the UK would have had rusty rear arches. So then I would have been back to cutting all the rot out, importing new panels from Germany and then spending weeks cutting and welding new panels in.
So I decided the easier and better option would be to change the roof.
I'm very pleased with how its turned out.
Apart from the seem of weld below the windscreen that still needs grinding down, filling and painting, its not easy to tell the roof has been changed. Its an almost invisible repair!
Tyre Pressures.
Tyre pressures are something that I think a lot of people overlook when off roading in the UK. The ozzies seem pretty clued up on it and seem only to quick to stop and drop the tyres a bit more. But here in the UK most people simply dont bother. They run road pressures all the time and never bother dropping them when they go off road.
In fact I'm sure a lot of them dont even bother checking their pressures very often/ever.![]()
My suzuki mates who I go green laning with never drop their tyre pressures, the guys I was out with this weekend, didnt bother dropping theirs, people just dont seem to bother over here.
But I know it makes a huge difference!
Not just in sand or snow but in most off road situations.
I've always found in the UK if I drop below 10-15psi I often start rolling the tyre off the rim.
Of course bead locks would sort that, and thats something I will be looking at in the future.
ARB air lockers.
ARB only recommend grinding the pinion if you havnt got the clearance that they specify. When my locker was fitted we had more than the specified clearance. So as far as I am concerned the ARB instructions are wrong in that the clearance they specify isnt enough.![]()
Tyre Pressures.
Not just in sand or snow but in most off road situations.![]()
Of course bead locks would sort that, and thats something I will be looking at in the future.![]()
ARB air lockers.
.Hello Ben.
First of all I want to congratulate you on an excellent thread an a great truck. I found it late and has been catching up during slow hours at work for months now (too few slow hours unfortunately). Nice job with the roof change. I had some problems with my own truck (see pic) and I just didn't dear straighten and weld it. So I bought another LJ70 with a faulty engine and just swapped over all the good parts from this one.
I've been meaning to ask about you experience with tires and tyre pressures and then I read this it gave me the perfect opportunity.
What is the deal with 20psi? I only offroad in Norway where there is a lot of snow, so maybe that's what's different. But here we typically air down to 8-10psi. In cold weather and light snow we often go down to 6psi and on my bead-locked 33x12.5 R15 I have gone as low as 3.5psi without problems.
What's your take on air pressure?
Wrong!
Right!
Wrong!
On a truck with a separate chassis, the identification is with the chassis, not the body.
So you can change the body (well any part actually) just not the chassis, as thats what has the identity.
Dropping tyre pressures does do less damage to the trail.
Not all bead locks are illegal for road use!
You can get internal bead locks like the ones made by Staun, and they're fully road legal.
That said their is loads of people running 35"+ tyres and bead locks in OZ. Totally illegal maybe, but people do it and get away with it.
Anyway................................................
Had enough of this bloody freezing weather now.
Another 12 days and I will be in my shorts enjoying the great Ozzy summer!![]()
Gra, i am currently running 35x12.5-15 creepy crawlers on my lj70, on i think 8" wide rims, currently i air down to 0.5 bar and don have any problems... I do plan on getting beadlocks in the future though, just for safety![]()
I run my 35 x 15 x 12.5 tyres on 10J rims and they usually have to use a bead cheat to get the tyre seated.![]()
Trail gear.
Have you any experience with the trail gear stuff, in particular the ring and pinion sets?
If upgrading to trail gear will give me a stronger, more reliable truck then I'm up for that! I'm very tempted to turn mine into a challenge truck and start competing in some competitions.![]()
But why have I never broken a CV or half shaft?
My CV's have been clicking like mad for the past year or 2, and as far as I know they could well be original items so 150,000+ miles old.
I've driven my truck very hard at times the with the aggressive 37" tyres and both ARB air lockers engaged.
Surely an already clicking, worn CV should be weaker than a ring and pinion?![]()
That truck looked good before the spill.
As far as air pressures go, I was told no less than 1 bar, which is about 14,5 psi.
I don't know if I would dare let them down to 8 psi to 10 psi.
Also, no unnecessary turns, keep it strait as much as you can.
Normal beadlocks only work on the off-side, which leaves the inside edge unprotected. There are inside beadlocks which can be inflated once the tyre is fitted. These effectively force the beads against inner wheel rim.
I have never needed to lower my tyre pressures for green lane use. If a section is that "difficult" that lower tyre pressures would seem essential, then I would either find another route so that I did not create further damage, or I would winch through. I am not being patronising here but I have seen people powering through sections just to prove it can be done, when a simple and far less damaging winch pull, was all that was required.
