I got all my stuff sorted out and made space for LJ in Michael's garage.
Then Michael asked if I fancied coming out with him to see what he does for work and giving him a hand.
I thought it might be a boring job cleaning carpets, but Michael specializes more in insurance work and in particular flood and fire damage.
Our first job was a flood. In some ones house the main water pipe to there dish washer had split and flooded the entire house.
We got to the job and Michael fired up the huge water pump/vacuum machine in the back of his van and ran the hose into the house.
I then spent the next couple of hours riding
Rover around the house and sucked up 600 litres of water!
We then brought air movers (special fans) and big dehumidifiers in and set them all up. They will then be left running 24 hours a day for the next 4-5 days.
I found it all quite interesting and it certainly felt good to be helping people.
The company then paid for me and Michael to have an amazing steak in the the city.
Yesterday after going and removing equipment from a few jobs Michael took me to meet some friends of his, Simon and Miranda.
Simon and Miranda own and run a production company making 4wd programs. Last year they produced 110 30min shows that are on TV over here every week.
http://www.your4x4.com.au/index.php?option=com_content&view=article&id=82&Itemid=100
They are both great people and Simon took me into the studio/office and spent a few hours showing me some footage from some of the places theyve been to and some of there favorite bits of the shows.
Some of the 4wding they filmed in Hawaii and Thailand was crazy! As was this years Tuff Truck event which I really wanted to go to.
The 40 series hes built is amazing and hes got some great videos of him driving it off road.
I was discussing with him the state of the 4wd industry in Australia, and what 4wd Action/Tigerz11 and Roo Systems are doing.
He then started telling me about a chap who had arranged for a landcruiser to go to Roo Systems to have a lot of work done to it to get it ready for a big outback trip, and how they had made a complete mess of the truck and had fitted second hand suspension instead of new, and a huge list of other really bad things.
I said thats my mate Tony! How did you hear about that and he said hed rear the report.
So it looks like some pretty big people in the industry over here know about what they did to Tony's 40.
Simons gorgeous 40 series wasnt at the house unfortunately.
But his 80 was with its 5" suspension lift, 35" tyres and hundreds of spot lights.
After a very enjoyable few hours spent with Simon and Miranda we came home and had a look at fitting Michael's prototype front drive shaft that hes had made for his suzuki.
It needs a bit more machining on a lathe because its a little bit too big.
After putting his Suzuki back in the garage we could finally put LJ in.
I'm now looking at which bits to order for the front axle rebuild.
So I want genuine KOYO bearings to replace the 4 king pin bearings, 4 wheel bearings, and the 4 bearings inside the front diff.
Genuine Toyota outer oil seals for the front axle, and the pinion oil seal on the front diff.
I'm going to buy some Trail Gear bits....................................
I want to do away with the OEM felt, rubber and thin metal setup on the front ball swivels and fit this:
http://locktup4x4.com.au/trail-safe-wiper-ball-kit-1356.html
I'm also going to try some of there inner axle seals which will work out cheaper than Genuine Toyota and should in theory be better.
http://locktup4x4.com.au/heavy-duty-front-inner-axle-seals-pair-274.html
Now in my mission to build a super tough and reliable 4wd I'm thinking should I not also fit an uprated set of CV's or CV's and shafts?
Sure its more expense but the idea is to fully rebuild the front axle and diff, get the diff professionally rebuilt with my air locker and all new bearings and seals. Replace all the wheel bearings and king pin bearings upgrade to new wiper ball kit, so that hopefully It will all be reliable and I wont have to touch the front axle again for a while.
http://locktup4x4.com.au/longfield-30-spline-superset-969.html
http://locktup4x4.com.au/dirty-30s-30-spline-cv-axle-kit-1336.html
Thee only issue is that both longfield and the dirty 30's are made from chromoly which wears very quickly especially compared to standard OEM ones.
Michael has got longfield shafts and CV's on his 80 but he wont run them all the time as they wear far too quickly apparently. So he only fits them when he runs his 37" trepador tyres.
Not a huge issue on LJ as obviously on road the front hubs are un-locked and it just runs in 2wd and I dont do huge miles anyway. Although I am planning some huge trips.
But then I've never broken a shaft or CV yet and thats despite driving LJ pretty hard at times. But I guess it would be better to upgrade now and prevent blowing a shaft/CV when I get some where like the Telegraph Track in the middle of Cape York.
Another job I need to do is to replace the leaking milner rear main seal with a genuine Toyota one. Not a job I'm looking forward to because I remember how heavy and awkward the gearbox/transferbox is to get out.
At the same time I'm going to replace the engine sump as it looks very rusty in one corner, and as its off an IFS 4-runner is holds less oil. I'm going to fit the bigger, rust free sump I got off Johnie.
