I randomly woke up 2 hours before my alarm today and thought I'd get the update done.
OK so Frankenzuke first..................
I needed to fill in the inner guards after all the trimming to get the 37" tyres fitted.
Still need to do the fronts but the rears are done.
The next job was to build a center console to fit switches and gauges into.
Cardboard template first.
Transferred the size and shape onto aluminum allowing for a 25mm fold all the way around.
Cut the middle out and folded the edges.
Made the sides.
Drilled and rivnuted.
Other side.
Switches and gauges next.
I decided to use a carling switch pod rather than cut out each individual switch slot in the aluminum.
Gauges next.
Pneumatic air locker switches next.
Added a double 12v socket.
Selected the carling switches. Id been waiting for an opportunity to use a Zombie switch since I first saw them in the huge tray of carling switches a few months ago.
(Apologies the pic is the wrong way around.)
I was then ready to finish the aluminium.
The masking tape is there to hold the rubber trim in place while the silicon dries.
The vitara we sent to the paint shop has come back and looks great. Lots of work still to do but it will soon be looking good and ready to sell.
We had yet another 70 series in to have the standard Toyota snorkel changed as there not watertight! Still amazes me that Toyots fit 2 part snorkels that arnt watertight to these vehicles.
Old one off.
New Safari one fitted.
It was an almost brand new duel cab 70 series that had been converted to auto.
Apparently they buy brand new 200 series auto boxes and then mate that up to the V8 TD engine.
Loads of room inside the cab.
Factory lockers.
I'm sure the seats must be a lot higher in these new 70's than in older 70's like LJ.
When sat in LJ the top of the door is roughly half way up my chest, but sitting in this 70 it wasnt much higher than my hips.
OK..........................Back to my winch rebuild.
New intermediate gear as I'd decided the old one was a bit worn and as i'd changed all the others it seemed crazy not to change this one.
I needed to drill and tap the new top housing for the breather and oil fill plug.
Needed to swap the free spool bit off my old top housing onto the new one.
And fit the new 6HP winch motor gear.
New motor next.
The free spool works by disconnecting the motor from the gears.
Free spool in.
Free spool out.
Came to tighten the 2 bolts up that hold the motor on and the first one was fine but the second one was just turning and not getting tight.
Took the motor off and realized that the top housing was damaged.
I considered using a hellicoil or welding up the hole and then drilling and tapping a new thread but I'm not that good with the fronius or TIG welders yet.
So a simple plan was formed.
Cut the head off one of the bolts and cut some of the heat shrink back.
Cut and ground a suitable bolt to the correct size.
Clamped it all in place.
Welded it.
Ground the weld down.
Quick coat of paint.
New heat shrink.
10mm longer.
I was then able to use some plasticine to help hold the nut on the spanner.
And thread the spanner down inside the housing and onto the end of the bolt I'd just made.
Worked perfectly and I was able to get the motor nice and tight on the housing.
The next job was to bolt and silicon the top housing on.
The next stage was to fit the brake assembly.
These 2 pieces of metal are used to help hold the brake assembly together so it can be fitted/removed from the winch.
Assembled and ready to have the center spring compressed and the 2 pieces of metal put in place.
Woodruff keys in next.
Followed by the circlip.
All the old parts.
Filled it with oil next.
Wired up and breather tube connected.
Rope on.
I love how fast and smooth it now is.
Last job was to run a twin core cable from the dash to the winch and use it to switch the thin negative wire going from the solenoid to the winch motor. This is to give me a winch power on off switch on the dash.
OK back to the overheating issue.
I found to remove the rad cowl I needed to remove one of the batteries as I couldnt get to the bolt any other way.
Also had to remove the bottom splash guard.
To get to the bottom mounts.
Cowl off.
The radiator does get quite a bit of air flow.
I took it for a drive without the cowl fitted and it was a lot better! It didnt get any where near as hot as it did with the cowl fitted, so the cowl must be preventing airflow. I think the fact it was so close (20mm) from the radiator and the fact it is square as apposed to chamfered towards the fan like the standard ones seem to be must have been affecting it.
Anyway.................
I took the cowl to work to modify it. This is only being down as a temporary measure so I can go on the next trip. When my viscous fan gets here I will build a new cowl and it will be almost pyramid shaped like the standard ones are so that the it slopes inwards towards the fan if that makes sense.
So Id worked out I could space the cowl and extra 30mm away from the rad which should improve air flow through the radiator when driving.
Cut a slot out so I dont have to remove the battery again.
I haven't had chance to fit the cowl yet but I'm hoping to tonight. Fingers crossed it fits.
I knew the bushes on the rear trailing arms were pretty shot so decided to swap the arms for my spare pair.
Couldnt believe quite how shot they were!
Sadly even my spare pair weren't much better.
So I need to get some new bushes ordered and fitted before this weekends trip.
So a few things still to do but I'm getting there.
Almost forgot.................
Work is still progressing on the house. The study and toilet are now practically finished. I spent most of Saturday painting them.
Before I gave the rooms there final coat of paint.
Study.
The next room were doing is the bathroom and that will take up the whole of November and should cover the rent for the next few months as there will be a lot of work in it. Were changing the layout so I will have lots of plumbing to do as well as loads of ceramic tilling.
But then I've got 5-6 weeks off work for my big road trip.
I've also got loads of work planned for LJ over the next few months.
Planning on pulling her all apart and completely re-wiring it and getting the electrics spot on. Its going to be a work of art!
Also want to get the body work done and the big re-spray.
Build an internal cage/cargo barrier.
And fit 3 batteries under the bonnet. I've worked out if I was to turn the 2 batteries so they face the other way I could get 3 batteries in that spot. So can have my 2 main starting and winching batteries and then also have a 3rd battery for powering my fridge. Will just need to design and build a battery tray and then build it and get it electro plated.
Oh I also picked up a new piece of glass for the rear door yesterday so I will get that tinted and fitted over the next few days.
