thanks Adrian.
Roger it was -2 at 7.30am here on monday morning, but im sure it felt a lot colder due to the amount of wind that comes across the open fields where the 4-runner is parked up.
the cold caused me huge problems on monday morning driving to work.
i put 20litres of veg in the tank on sunday morning and she ran perfectly all day, i did quite a few miles, and thought id used most of the veg up, but i hadnt. what i should have done, and had every intention of doing was to stick 20litres of derv in the tank sunday evening after laning, but i thought it would be ok.
driving to work monday morning the truck got slower and slower and slower, to the point where it was only doing 20mph and had no power at all. all due to the veg oil going very thick in the cold weather. had to fill a drum up with 20litres of diesel, then when i got back to my truck in the evening chuck it all in the tank and leave it running for 10minutes so it pumped the diesel through the engine. that fixed it and it drove home perfectly again.
i must be more careful now the cold weather is coming and not run on 100%veg oil again.
that reminds me, the heated fuel filter housing ive fitted.
ive noticed on my fuse box ive got a fuse marked fuel heater, and there are wires going to it. do you know where the fuel heater relay is located on your kzj70?
ive removed the one from the 4-runner and want to get it fitted and wired up on mine.
regarding the X-brake, i did notice when i had the rear axle jacked up off the ground and was checking to see if the front prop was turning, that the disc didnt look like it was turning perfectly, and did look ever so slightly buckled, but i havnt got anything for measuring this.
thanks for all your suggestions, i will work my way through the list, and report back with what i find.
