- Oct 13, 2010
got to work at 7am today so i could spend an hour painting my new sliders, before having to start work.
coat of red oxide primer.
then in my dinner break at work, i nipped to maplins and bought a multimeter, as my intention for tonight was to try and sort out some of my electrical faults.
my new manual also arrived today, courtesy of amazon.
id already got another max ellery manual, but it didnt seem to cover my truck in the sort of detail i need. the new manual is very good, and has a lot of good information in.
this is my other manual.
so at 5pm when i finished work, i connected the 3 wires to the alternator and it seemed to be working perfectly.
volts started going up on the voltmeter, and sat nicely in the centre of the gauge.
checked what voltage the batteries were getting from the alternator.
next i decided to try and fix the windscreen wiper fault. the windscreen wipers worked perfectly but kept blowing the fuse. so for the past few months ive been driving without them, which hasnt been good in heavy rain.
i tried to think when this fault first appeared, and it seemed to be since id done all the bodywork. when i did the bodywork i replaced the bent rear door, but i never changed the windscreen wiper motor in the replacement door. so i suspected this is where the fault might be.
so i removed the relay for the rear wiper, and this seems to have cured the fuse blowing issue. granted i havnt currently got a working rear wiper, but at leats i can now see where im going in the rain.
next i changed the steering bar i bent at Lincomb.
so one bent steering bar, with decent rubber gaiters. and one straight bar with knackered rubber gaiters.
got the new bar in the vice, and removed the damaged gaiters.
and fitted the ones i removed form the other bar.
new bar fitted.
gave the sliders a coat of black enamel.
hoping to get the sliders fitted tomorrow.
new bar fitted.
