i dont update this thread for a couple of days, and now i find ive got over a 100 pics to sort through, re-size and upload!
i wonder how much quicker my truck would get done if i didnt take so many pics?
so Sunday morning after a few hours on skype i set about finishing the front brakes!
first job was to clean all the oil and grease off the new discs. so gave them a good wipe both sides with a clean cloth and thinners, as didnt have any proper brake cleaner.
removed the passenger side pads.
pretty worn compared to the new ones.
managed to push the pistons back far enough to get the new pads in, but they were a tight fit.
passenger side done i moved onto the drivers side.
old pads looked even worse on this side, the pads were cracked and had areas of friction material missing.
one of the pins was also knackered, as the end had snapped off right on the hole where the spring clip goes through.
so i needed another one of these:-
if id had a nice lathe in my workshop then id have knocked up a perfect calliper pin.
but as i dont yet have a lathe i had to improvise.
found an old bonnet stay that was the perfect diameter of bar.
cut the end off the stay to the correct length, put a blob of weld on one end, drilled a tiny hole on the other and i had a new pin.
so that was that side back together.
decided seen as everything was going so well, id change the rear wheel bearing and inspect the shoes in the rear drums.
so wheels off and axle stands under chassis.
jacked the side i wanted to remove the shaft from, to prevent me from loosing any oil.
drum off and shoes out.
half shaft out.
my first view of the bearing that needed replacing, another Koyo one.
so into the workshop and got it on the bench. removed one of the studs to make it a bit easier to get in with the angle grinder.
ready to begin grinding.
started by grinding a notch in the locking ring. was really really hard steel.
had to grind a notch both sides before it would come off.
next i had to dig out the bearing race, with a big screwdriver and hammer.
eventually i was able to get the balls out.
and shortly after the shaft was separated from the hub.
the bit in the hub was easy to knock out.
but the other bit, that was still on the shaft wasnt so easy.
more grinding.
and it became loose.
now id say that took probably 2 hours to get the old bearing off!
i love my truck, i really do, and i dream of driving it to really remote inhospitable places, but.......................
i dont like the fact i cant change the brake discs, or rear wheel bearings easily myself, with just a box of hand tools and a socket set!
so anyway back to the wheel bearing............................
the new bearing looked a bit differnet to the old one, as the new one had an extra bit on the side.
after doing some measuring, and thinking about it, i decided that milner have never sent the wrong parts before, and i want my truck back on the road. so lets knock the bearing on and see.
cue big mistake!
it went on, but not far enough. luckily i didnt also add the locking ring, as that would have made it even more difficult to remove.
so i then spent 2 hours removing it, with the angle grinder and big screwdriver.
more filling and sanding on the rear quarter.
got the rear bumper sanded down and painted.
havnt run with my other set of wheels and tyres for a long time, and as ive got a lot of road miles coming up, decided to stick them on.
sprayed the rear quarter red. this is so when i sand it down with wet and dry paper, the red paint will get sanded off, but it wont get sanded off where all the low spots are, and these are the bits that need more filler.
sanded it down this morning, and then put a load more filler on it this evening.
called milner this morning and they were very sorry theyd sent me the wrong bearing and promised a new one will be here tomorrow, free of charge of course.
decided to finally make a start on the steering guard MK2.
so new plate versus old guard.
love that!
cut a piece of 100mm x 6mm flat to length and marked where the holes needed to be.
got the end holes drilled with a hole saw.
and drilled the middle bigger 2 holes.
its amazing how quickly big holes can be put in thick metal, when using a decent drill on a slow speed, with decent hole saws and plenty of cutting fluid.
test fitted it.
put a piece of 50mm x 5mm flat in the vice.
and cut 2 110mm pieces, and welded them to the 4" flat.
ground the welds down on what will be the top side, as they would prevent it sitting tightly against the underside of the winch tray.
but left the welds on the other side.
tacked the big piece of plate to the 4" flat.
checked the angle was the same as the first guard.
cranked the amps up on the ARC welder and fused the 2 pieces of metal together with 4 rods!
cleaned the welds up with a flap wheel disc in the grinder, to make the edge nice and rounded.
couldnt resist bolting it in place.
would it be sad of me to fit a small light to the underside of the winch try, wired up to the side lights?
this is with a torch shining behind.
need to take it back off and cut and weld the 50mm box section to connect the bottom of the guard with the top pieces of 50mm x 6mm flat i welded on.
im very pleased with how the magazine subscription is working out. ive just finished reading all 300 pages of the first 4WD Action i received, and a new one arrived today!
