thanks Andrew, its getting there slowly.
so yesterday i finished the welding underneath, and then cut the piece of rot out of the inner arch.
and welded the patch on.
whilst scraping the melted paint off around the weld i found another small area of rot, so i poked it and bashed it till i was back to sound metal, so i patched that aswell.
i then finished welding the panel around the rear light.
next i started some re-assembling.
so i refitted the rubber strips onto the fuel tank hangers.
i used mitre mate to stick the rubber squares back on to the fuel tank.
so fuel tank, guard, and hangers all ready to go back on.
fitted.
next i took the 2 exhaust heat shields and a front guard and steam pressure washed them clean.
i refitted one of the heat shields.
next i turned my attention to refitting the rear suspension. aswell as the bottom shock bushes being slightly worn due to not having a washer fitted above them, i noticed the same was true on the top, the metal surrounding the top shock mount has worn into the bush.
i dont know why i didnt fit washers when i fitted the lift kit.
i needed some washers with quite a big centre hole to fit over the shock mount, but couldnt find any suitable, so i made some using a hole saw in the drill.
new home made washer in place.
shock fitted correctly.
i fitted the panhard rod, and reconnected the 2 fuel lines, brake line, handbrake cable, prop shaft, and axle breather, and then put the wheels back on.
that was the end of sunday. next job was going to be fitting the new back door.
so today i finished work, and started on my truck. i removed the back door, and laid the new one inside ready to strip it down.
first job was to remove one of the hinges as it had been cut clean off.
i noticed some rust behind the hinges on the body, so i sanded this down before rust killing it.
i removed one of the hinges from my bent door to replace the cut one.
the catch was badly bent and twisted, and the electric wires had been cut through, so i needed to remove both these parts from my original door.
i bolted the door on, but found it needed lifting up as it wouldnt shut properly.
so i used a ratchet strap to lift the door up with all the bolts slackened off. once the ratchet strap had lifted the door up i tightened all the bolts up.
bent catch and new one ready to be fitted.
fitted my electrics and rear washer hose through into the body.
next i removed all the latch parts from the bottom of the door as there very badly rusted. i will use the ones off my old door once the new doors been painted, as my old ones are in better condition.
need to remove my old rear window as its tinted.
the rust inside the new door, much worse than my old door, but at least the door is straight.
treated it with rust killer.
the inside of all the doors will be getting a very good coat of waxoil to hopefully prevent any further rust.
nice straight doors.
i definitely want some new wheels with more off set, as the wheels still seem far to far inside the arches.
i then used some seam sealer in a few small areas in the wheel arch where i couldnt get into weld.
and that was it for today. :handgestures-thumbup:
quick question.................
are all these hoses needed coming out of the tank to the filler neck?
theres 3 hoses in particular that i want to do away with, as one of them has a hole in it due to rust. theres 3 hoses coming off the tank next to each other. 2 go up to a cylinder thing, then one comes off the top and links back to the tank.
any one know what there for, and if i can get rid of them?
![Thumbup :thumbup: :thumbup:](/custom/images/smilies/pack2/icon_thumbup.gif)
