Lorin
- Mar 28, 2010
Since Lincomb I have a noticable loss of power - probably by about 30%
There are no other symptoms - it is not smoking, the turbo whistles and kicks in how it always did, the oil level is fine, there are no fuel leaks and no noises or warning lights, it simply has no power. On one hill that it normally easily holds 60mph up in 5th I ended up having to use third with my foot floored just to get up
It was serviced (i.e. all filters and oil changed) just before Lincomb and was running absolutely fine before and after the service. The fuel level never dropped below half at Lincomb but obviously the truck did get bounced around a lot
I first noticed the power loss driving round the woods in low range and thought it would just clear itself, but it hasn't.
One thing I've noticed is that if I feather the throttle it drives pretty normally. If I then give it any throttle it seems to hesitate as if it is not getting enough fuel. If I give it 100% throttle it very slowly picks up but again feels as if it isn't getting enough fuel.
Hoping it is something relatively minor I'm thinking it might be a fuel blockage somewhere. Other than changing the fuel filter what else could I change / where else should I look? Is there any point running a load of fuel cleaner through? Any advice would be greatly appreciated.
