Lorin
- Mar 28, 2010
As the title says, the truck failed the MOT as the LSPV is "not working" - became part of MOT this year. The issue is, I am a little dubious about the 'test' that is being applied
After the first fail I spent a bit of time under the truck trying to fix it - dissassembled and lubricated all moving parts - and I can attest to the following.... The whole LSPV 'arm' mechanism works perfectly. The piston in the LSPV itself also moves up and down smoothly with little pressure and there are no fluid leaks. I took it back for a retest and it got another fail
According to the MOT tester, the piston in the LSPV should visibly move "a little" when the brake pedal is pushed - that is the 'test' they are applying. However, I can't quite work out why it would move? I thought the piston simply changed the amount of fluid going to the back brakes (i.e. increased or decreased braking) - why then would it move when the foot brake is applied?
Does this sound like an appropriate test?
