Following on from my thread last night i have found the reason i could not get up the hill, i have no drive to the front wheels, i assume i jack the back up stick it in drive & if the front prop turns then i have a broken drive shaft.
i would not check it that wayjoinerman said:Following on from my thread last night i have found the reason i could not get up the hill, i have no drive to the front wheels, i assume i jack the back up stick it in drive & if the front prop turns then i have a broken drive shaft.
It won't be a problem as long as no one is underneathMark Whiteside said:i would not check it that way
because if you have drive to the front you will drive of the jack....
How do you know if you were in the truck? Not being funny, just trying to be thorough and avoid assumptionsjoinerman said:That's what i did the other night Jon, with the cdl locked just my rear wheels spun, the fronts did nothing.
Yes and no. You only have as much drive as the wheel with the least traction can support ... on a firm surface you're 4 wheel drive but put one wheel on something slippy and you're 1 wheel drive On an 80 the viscous coupling in the transfer box is supposed to provide some torque transfer to the other axle but it's not a lot. I'm not sure what the arrangement is on a 90. 100's are the same as an 80 without the VC.24Seven said:Without a center diff locked a "permanent" 4wd is really one wheel drive
