Pumpy
- Aug 6, 2015
Had a bit of a weird spot in the steering recently, as if it was catching on somthing at about 12-o-clock position, getting worse over the last 100 miles or so. Today it developed into a death wobble after hitting a pot hole on a duel carridgeway at 60mph, violent shaking of the steering wheel for around 10 seconds.
I lay under the truck while the Mrs gave the steering wheel a waggle, found the bottom Panhard Rod bush had lots of play in it (about 5mm), ordered polybushes for it, that should sort it. (£50 for both ends inc delivery)
