Military HID spots,Bike racks,hi-lift,trans cooler,VDO Gaugs
pugwash
Russian Military HID spots. These are not some cheap chinese knock-off, but genuine russian military HID posts, they are fully submersible, and genuinely Bulletproof
-[youtube:1w8b8afv]HH8GY_E31rE[/youtube:1w8b8afv].
they come with ballasts, are in fully working order, but cosmetically aren't perfect.
These really are of amazing buid quality- the lenses are about 1cm thick tougened glass, the body is hardened steel, all the ports of fully sealed, and the wiring is very high quality.
Bulbs are philips HID, and can be replaced quickly and easily.
these are very very very VERY bright, come with spread beam pattern as opposed to pencil spots.
£150
Witter Tow ball mounted bike carrier- very easy to install, and take off. leaves the rear of the car free of weight. Can carry up to 3 bikes. £40
Halfords Bike rack- used to strap this to my rear tyre carrier and it worked really really well- can also be used on most other cars too as a normal bike rack as all the fittings are presnt. £40
http://www.halfords.com/webapp/wcs/stor ... yId_165477
4 foot hi-lift- good condition, Mech could do with a good clean and lube though- has been used (even for an ELCO recovery training day!). £35 - probably pick up only!
Hayden Automotive high performance transmission cooler
A highly efficient cooler- fin row cooled (like a MOCAL, but bigger surface area), so can be smaller but provide better cooling. imported from the states and specced to cool a yank 4l80e (a massive 4 speed box) that was warranted to 600hp! This cooler looks small, but really shifts heat. Will be very easy to install as its very slimline but has great flow. Comes with all parts necessary to install. £50
VDO gauges- trans temp and Oil pressure- Trans temp in farenheit. may have suitable senders
Oil gauge- up to 100psi (cheap ones only go 80psi max). £30- sender if i have it- £5
trans temp gauge- can't get this in centrigrade! again £30 + £5 for sender if i have it
Re: Military HID spots,Bike racks,hi-lift,trans cooler,VDO G
PM sent, re the Trans cooler and gauge.
Spots, trans cooler and trans gauge gone.
Pm sent re Hi-Lift....
