Milners or OEM hub oil seals?
Brett
Whats the opinion on the Inner wheel bearing (hub) oil seal P/No. 90311-62001, should I go genuine or are the Milner ones ok? :?:
I have OEM inner axle seals already , as I know the Milner ones aren't so good.
I have milner hub seals in and they are ok and dont leak, but for how long I dont know. I fitted milner inner shaft seals as well but they both failed within 200miles so from know on im only going to use Toyota seals. ;)
As it's not the easiest of jobs to do, I would go with genuine :thumbup:
Yep. Critical part, do it once, do it right.
Hi, if you want the best oil seals take a sample size to your local bearing factors and ask if they have the same size in viton rubber ones they are only about £1.00 dearer and are much better than silicone type seals ,the easiest way to identify them is they are usually brown in colour.I have had these in my cruiser for about a year now,thanks Wayne.
