Oil contamination
JB, have you thought about fuel tank condensation?
It happens if you run your tanks low for a while. It may cost a lot
but fill them up and then top-up when you use 20 litres - may be the
best though not the least expensive solution. At least to give you
time to get another analysis after following this regime after
changing your oil.
Jon
Linslade, Beds
Jon,
Might be better than money in the bank at the moment - although you are
dragging a little extra weight around.
Are you suggesting that the water in the fuel might find it's way into the
oil, not come across that, where might the transfer occur?
Malcolm
Stafford (UK)
FJ45 '75 & FJ45 '76
-----Original Message-----
Behalf Of toyj80
Sent: 22 May 2008 09:25
To: [Email address removed]
Subject: RE: [ELCO] Oil contamination
changing your oil.
Jon
Linslade, Beds
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.24.0/1459 - Release Date: 21/05/2008
17:34
Checked by AVG.
17:34
Ahh, slow mind here today, perhaps condensation from the combustion blow by
past the rings?
Malcolm
Stafford (UK)
FJ45 '75 & FJ45 '76
Behalf Of Malcolm Bagley
Sent: 22 May 2008 10:55
Jon,
Malcolm
Stafford (UK)
FJ45 '75 & FJ45 '76
Behalf Of toyj80
changing your oil.
Jon
Linslade, Beds
Checked by AVG.
17:34
Checked by AVG.
17:34
Checked by AVG.
17:34
Checked by AVG.
17:34
Malcolm wrote ...
past the rings?
SNIP...
Correct.
As lectured to me at Ford Dagenham diesel servicing school circa 1970 !
Jon
Linslade, Beds
Big problem with engines running on landfill gas for power generation is the
contamination of the oil by acidic elements in the blowby gasses add some
moisture and it eats the engine from the inside. Solution is top quality
oil, special plating on internals, special bearings and oil changes every
500 hours (400+ litres a change, 18 changes a year = 7200+ litres of oil!)
Malcolm
Stafford (UK)
FJ45 '75 & FJ45 '76
Malcolm wrote ...
past the rings?
SNIP...
Correct.
Jon
Linslade, Beds
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.24.0/1461 - Release Date: 22/05/2008
16:44
Checked by AVG.
16:44
Jon
Do I remember reading somewhere that the oil level can give a falsely
high reading due to this, and that one should check it after a good run
has boiled off any water?
Christopher Bell
| Malcolm wrote ...
blow
| by
| past the rings?
| SNIP...
| Correct.
If there was that much water in the oil I would suggest the oil wants
changing immediately and the cause investigated. We never see more than a
fraction of a percent on sample analysis unless something is quite wrong.
Malcolm
Stafford (UK)
FJ45 '75 & FJ45 '76
Behalf Of Christopher Bell
Sent: 23 May 2008 10:22
Jon
Checked by AVG.
16:44
