Ahh, slow mind here today, perhaps condensation from the combustion blow by
past the rings?
Malcolm
Stafford (UK)
FJ45 '75 & FJ45 '76
-----Original Message-----
Behalf Of Malcolm Bagley
Sent: 22 May 2008 10:55
To: [Email address removed]
Subject: RE: [ELCO] Oil contamination
Jon,
Might be better than money in the bank at the moment - although you are
dragging a little extra weight around.
Are you suggesting that the water in the fuel might find it's way into the
oil, not come across that, where might the transfer occur?
Malcolm
Stafford (UK)
FJ45 '75 & FJ45 '76
Behalf Of toyj80
Sent: 22 May 2008 09:25
JB, have you thought about fuel tank condensation?
It happens if you run your tanks low for a while. It may cost a lot
but fill them up and then top-up when you use 20 litres - may be the
best though not the least expensive solution. At least to give you
time to get another analysis after following this regime after
changing your oil.
Jon
Linslade, Beds
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.24.0/1459 - Release Date: 21/05/2008
17:34
Checked by AVG.
17:34
Checked by AVG.
17:34
Checked by AVG.
17:34
