Oil level light
Burgo
australia
The oil LEVEL light remains ON - troopy yr 2000 1HZ. Mechanic tested sender ok. Light comes on after about 30 secs with sender connected OR DISconnected.
Any bright ideas please?
Burgo
Broken wire , I'm guessing but would it be set up so 2 wires are positive and negative and another connects to ignition switch ?
Not sure Guru - will have to investigate further. Thanks.
