Somewhere in my mind I thought it was supposed to be 75 psi. Need to look and find where I got that figure. I know whatever it was supposed to be, mine made it. 45 sounds a bit low. Must be in the FSM somewhere. I'll check.
Shortfall Clive? 60 psi is about midway between 36 and 87 so I’d say pretty good really. Oil temperature and viscosity is going to play a major part in this. I would have thought change in pressure over time would be of more interest.
The main thing is to have oil pressure at every point oil is needed.
Funny, I was only thinking about that this afternoon.BTW, I’m running on Morris’ oil as you might imagine Rich, seems to be on the button too... Thanks![]()
A compression test will give you a better idea of the state of the engine if thats what your after. Other than BEBs theres no other issues with bearings.
if it doesn't smoke excessively, knock,bang or rattle, and pulls as it should. You'll be 'reet..
