If its what I think you are refering to, it is literally 'sandwiched' between the oil filter & engine via an extension type thread, & has a couple of oil cooler pipe connections on it.
This then allows you to fit an additional engine oil cooler quite simply by connecting the pipework to these 'flow & return' connections.
