oils
Jeremy
I'm thinking of changing my choice of oil for next years trips to North Africa - at the moment its got Fuchs oil in the engine - I've only got about 3.5 ltrs of it left. I'd been using this for a number of years since I started travelling in NA, and got it (2 x 25 ltr drums) from a friend in Wales back in 2001 - it did well to last this long because I gather synth oil like bio oil degrades over a period of time, so am looking for a good alternative. If anybody's interested I'll provide a few details later this evening since I can't really remember its specs at the moment. At the time it was about =A375 per barrel/drum. I thought this was pretty good at the time and it did wonders for the engine in the desert - even a friend of mine whome I was travelling with in NA asked if I could spare a few litres, I had spare, and gladly let him have some.
Renate
>>> [Email address removed] 12/17/04 09:48am >>>
Wrote:
Still intrigued by what oils everyone out there uses...
Hi,
That is a very good price for synthetic oil especially if it is full
synthetic. I would be very interested in the spec if you have time.
Anthony Graham
1994 1HD =96 T
West Wales
_____
Behalf Of Renate Haupt
Sent: 17 December 2004 10:05
To: [Email address removed]
Subject: Re: [ELCO] oils
Jeremy
Renate
I'm thinking of going over to synthetic fluids all round. If anyone
uses any, or has any info. I would like to know.
Thanks, Clive.
HDJ81
On Fri, 17 Dec 2004 13:40:12 -0000, Anthony Graham
On
out
is
me
the
ine
had
Hi Clive
Renate is also thinking of doing the same to a degree there is a book on the
subject called THE ENGINE OIL BIBLE that will tell you all you need to know
about oil I think.
Hope this helps if not post again.
John c
92 HDJ 80 1HD-T Ireland
----- Original Message -----
To: <[Email address removed]>
Sent: Saturday, December 18, 2004 6:08 PM
Thanks, Clive.
HDJ81
Hi Clive,
I used Car Lube Full Synthetic Oil 5W - 40 =A324.99 for 5 liters. I chose the
brand only by price and grade, I prefer to use full synthetic. I one reads
the small print many so called synthetics are "synthetic based" or contains
synthetic and avoid contravening trade description acts for making false
claims. Based or contains can mean any thing they normally do not say, so I
play it safe and buy a full synthetic. I believe there are a few advantages
as synthetic tend to hold grade under extremes and there have been claims
for longer oil change intervals. The other oils are probably OK it is just
my choice. Normal mineral oils have been used with success for many years
and some meet high classification standards. I have used synthetics for
quite a few years in other vehicles and have been impressed by the lack of
sludge even when greatly extending the intervals.
Anthony Graham
1994 HDJ 1HD - T
West Wales
UK
-----Original Message-----
Behalf Of Clive Marks
Sent: 18 December 2004 18:08
Thanks, Clive.
HDJ81
On
North
about
I
in
synth
good
this
time
the
of
mine
I
had
John
The book is $10, the list could put a dollar each towards a copy of the
book...?
list guys, any thoughts on this?
>>> [Email address removed] 12/20/04 02:52pm >>>
Hi guys
I found most of the stuff on oils that I have. The MOTOR OIL BIBLE has
a big warning on it about sending it in part or in whole to any one with
out written permission from the author. I can under stand why, he makes
money on the sale of the e books so I dont think I should go against
this. I will see if I can look him up some where and see what the story
is .
John c
92 HDJ 80 1HD-T Auto Ireland
Julian et al
Having said this - the contents of this book might not warrant =A30.50-0.60 to spend on it...
Renate
On 30 Dec 2004 at 20:34, Ian Packer wrote:
I just added an interesting note on CF vs CF4, in the context of high-
sulfur diesel in Africa and east-block countries....at the end of
this otherwise even more interesting article about differences in oil
for Japanese/US/European engines:
http://www.a1.nl/phomepag/markerink/80bigend_oil-analysis-scam.htm
Bye,
Willem-Jan Markerink
The desire to understand
is sometimes far less intelligent than
the inability to understand
[note: 'a-one' & 'en-el'!]
Willem,
Very interesting reading.
However I'm still wondering which oil I should be using that's available
in the UK? I have a Jap import so it has only done about 10,000 miles on
UK oil and I'd like to use one to avoid the bearing problems. But which?
Amsoil is pretty rare here, in fact I have no idea where to get it. Is
all Amsoil ok or just specific ones? So far I have been using Castrol
GTD because it was cheap and I thought why use expensive synthetic oil
as that still has problems if it's the wrong make. So I wonder does
anyone know of an oil that's readily available in the UK that is good
for my 1HD-T?
I tried discusssing this with Toyota but as expected they were simply
not interested in an old imported car.
Thanks,
Ian.
Willem-Jan Markerink wrote:
Free classifieds for anything 2 wheeled:
http://www.fud.f2s.com/classifieds/classifieds.php
Layman's ROW guide: http://www.rightsofway.net
Hi Ian,
An address for Amsoil http://www.debben.co.uk/acatalog/index.html
An address for Red Line
http://www.demon-tweeks.co.uk/catalogue/category_list.asp?TLGRP=3DR009&PGRP=3DR0
09&CLS=3DROAD&GRP=3DRP081&sortby=3D&brand=3DRED+LINE
Anthony Graham
1994 HDJ80 1HD - T
West Wales
UK
Behalf Of Ian Packer
Sent: 01 January 2005 08:57
Willem,
However I'm still wondering which oil I should be using that's available in the UK? I have a Jap import so it has only done about 10,000 miles on UK oil and I'd like to use one to avoid the bearing problems. But which?
for my 1HD-T?
Thanks,
Ian.
think,
Hi Ian
Here is the only Guy who I know did or does Amsoil in the UK. Try
[Email address removed] . His name is Chas Stafford, and he is in North
Devon. He is a really nice guy. I was going to get a load of oil off him for
the engine and the gearbox aswell as the axels last year but it is much more
expensive than the Dino oil or other synthetics but is suppossed to be the
best. He probably remembers me because I nearly bought but found at that
time I could not afford it with the shipping. No body here in Ireland deals
in the Amsoil and it is expensive enough with out putting shipping charges
from the UK to Ireland on top of this aswell. If I could I would use the
Amsoil but its like every thing here nobody does the good stuff and to get
it shipped just adds to the cost. I use a dino oil called Maxol Optima
which is suppossed to be very good and only costs 99 Euro for 2x 23 litres.
I change the oil every 3000 miles like clock work. Try
[Email address removed] for the Redline I also tried them last year.
Hope this helps
John c
92HDJ 80 1HD-T Auto Ireland
I've been reading and searching the web.
I am struggling to come up with a suitable oil readily available in the
UK! Has anyone found a Jap spec oil?
The best I have come up woth is Amsoil 15W/40 but it's being offered at
?36.50 per 5L plus shipping!
That's a little pricey and would make it cheaper to change the bearings
every 50K.
Ian.
Hi Ian
I know how you feel about the oil issue for your cruiser. I know Amsoil is
very expensive and I think I posted about that a while back, but it is
supossed to be the best. You pay for what you get. I love saying that
because thats all I hear other people say. Look it all comes down to money
in the end. If you use a really good oil it is better for your engine and
your turbo because it has better cleaning properties, and should not burn
off as easly at the high shear areas of the engine and will deal with the
heat of the turbo better unlike a normal mineral oil. In saying that the
cruisers have gone well on the normal 15w40 oil since they were built, once
the oil is changed regularly. There is no doubt that the synthetic oils are
better and some of them are better than others depending on the base stock
used, but there is a price to pay for this better stuff for the cruiser.
Some of the better synthetic oils will say they are good for extended oil
drains which is great and will bring down the price you pay for them by
about half if you compare like mileage for like. They will still work out
much dearer than a normal mineral oil and thats where you have to make the
choice and way it all up. Some of the newer cars are now saying they will go
20,000 miles with out an oil change on a good synthetic oil. But there is no
way I would do that and expect the engine to work well in a few years. All
that combustion going on in the engine with its residue and leaving it there
for 20,000 I dont think so. All oils degrade with time and wear in the
engine, some give better protection for longer than others, some have better
pour point, flash point, viscosity index, ash content, and other specs than
others but you will pay more much more for a better oil , there is no way of
getting out of it. I would love to change to a better oil , but even the
shipping from the Uk for 50 litres is around ? 80 then I would have to pay
for the oil.
Anyway look at cplubricants.co.uk they do a 15w40 for ?92 for 50 litres and
their specs are good.
John c
92HD80 1HD-t Auto Ireland
------=_NextPart_001_0002_01C4F3EE.65853050
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Ian
Here is the specs on that oil. Hope this helps, let me know if it went through ok.
John c
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2523" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi Ian </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Here is the specs on that oil. Hope this helps, let
me know if it went through ok.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>John c</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>92HDJ 80 1HD-T Auto
Ireland</FONT> </DIV></BODY></HTML>
------=_NextPart_001_0002_01C4F3EE.65853050--
john byrne wrote:
Decided to bite the bullet and ordered the Amsoil Synthetic 15W/40 Heavy
Duty Diesel Oil on the basis that I should be safe to extend the drain
to 6000 miles which makes it acceptable. I'll be mightily disappointed
if my bearings fail now because it aint cheap! I've only done about
12,000 miles on non-Jap oil so I'm hoping mine are still in good condition.
Ian.
Hi Ian
Did the guy you are buying the oil from advise you on what to do before
you use the oil. I think I would have done the same but the shipping
puts me off.
John c
92HDJ 80 Auto Ireland
Hi Ian
There are a few things you need to know before you do the switch to your
synthetic oil.
Do you have any seal or gasket leaks at all now, if you have, these will
possibly get worse because the synthetic oil is lighter than the mineral and
so will seep a little more..
Mineral oil builds up sludge and varnish on various parts of the engine and
seals over time and because of the better cleaning ability of the synthetic
oil, it will clean your engine much better than it has been up to now.
You could think about using a engine flush before you use the synthetic.
Amsoil do one which is supossed to be good. Im not too sure how much but I
think its one bottle for a normal engine so I would presume it would take
two bottles.
This will clean out most of the gunk in your engine rather than having it
floating around in there.
You should change your oil filter before you put the new oil in.
Step 1 Have your engine oil warm as usual before the change.
Step 2 Change your oil filter and put a new one on,
Step 3 Run engine to fill the new oil filter.
Step 4 Check dip stick and ensure there is room for the engine flush
either one or two bottles.
Step 5 Run engine for a few minutes to get the flush to work.
Step 6 Change oil and put new filter on.
The previous oil filter should have taken most of the dirt that was released
by the flush. It may also be a good idea for the first oil change with your
synthetic not to let it run for the 6000 miles as more stuff might come lose
from the better cleaning ability of the synthetic oil. I would also think
about changing the oil filter early just to help aswell.
John c
