Sounds like another frustrating day Did you try an ECU swap? At least that doesn't involve taking the oil pan off again!
.Jon Wildsmith said:I think you've confirmed the solenoids and wiring should work if power is applied to them, but haven't yet established the ECU is powering them (e.g. internal component failure, dry joint etc) 2 options IMO both involving tapping into the solenoid wires close to the ECU, either by removing a small amount of insulation or a scotch lock. 1st option, with the engine running and the box in D, check there is 12v going to S1. If there isn't 12v, add your own 2nd option, if there is 12v going to S1, try connecting S2 to 12v and see if there's any drive (that would be forcing 2nd gear instead of 1st).
I've got one of these;Graham said:I have used a sewing needle in times gone by.
Short length of wire throuh the eye. Use pliers to push the pointy end through the insulation.Just an idea.
G.
Someone better tell Dave what I do for a living.
What do they say Chris, . . . sometimes my voices have good ideasChris said:I'm frightened of trees. They talk you know..Chris
