Here's the deal - after a bit of fun at Kirton, it's overheating - but only once you crack 42mph it seems! At idle, or trundling round the off road site, it's rock steady in the usual position. Will seemingly idle for ages with no concerns. I jetted the rad in case it was blocked but that didn't help and had to resort to calling the AA. According to his combustion gas test, it's fine. Pressure does build in the cooling system however.
Any thoughts? Try no to mention cracked heads if you can at all help it...
