Part No. Request
Roger
Hi All,
Land Cruiser HDJ80 - 1993 4.2td
Does anybody know the part no. for the power steering pipe setup from the reservoir/pump down under the radiator and across to the steering box? Both flow and return pipes.
The metal section on mine has corroded away to dust now - temporarily fixed with rubber hose but I think it was designed as metal and placed where it is to act as a basic oil cooler as well.
Roger
Hi Roger,
On my vehicle its this page on toyo diy, if you put in your chassis no and search power train chassis (2) and then power steering tube (45-03) that should give you some options, mine is 24v diesel, I don't have your chassis no so cant double check but you could have exactly the same parts as mine.
Good luck
Hi Roger,
Good luck
Nice one Julian, thank you - that worked a treat.
