I got my local garage to do the bottom one, but used the tool to do the top one, worked very well with just a tap from a BFH to get it moving, also pressed in the new one easily, only problem was clearance from the inner wing.uHu said:To change the lower ball joints takes a bit of force, yes.
It's hard to do with the A-arm still in place. To get the old one out can be done with a bfh, but to get the new one in requires a LOT of force. The C-clamp kit shown in post 2 doesn't look like it would be strong enough. I would say a 10 ton press would be a minimum, maybe with a bit of bfh-help in addition.
Not to be confused with separating the lower ball joint and the knuckle, which is normally easy with a bfh, even with a normal hammer.
Do you know what tool they used for the lower ball?andyw said:I got my local garage to do the bottom one, but used the tool to do the top one, worked very well with just a tap from a BFH to get it moving, also pressed in the new one easily, only problem was clearance from the inner wing.
uHu said:Do you know what tool they used for the lower ball?andyw said:I got my local garage to do the bottom one, but used the tool to do the top one, worked very well with just a tap from a BFH to get it moving, also pressed in the new one easily, only problem was clearance from the inner wing.
Would like to be better prepared for the next time.
That kit you used for the upper ball, what is it called? Specs? Source? etc.
