Hi Ed,
Apologies for not getting back to you sooner, been mega busy today.
So setting the bearing preload on front wheel bearings.....................................
As per the FSM:-
Once youve pushed the hub back on and with both bearing races in place, you put the washer on and then the first 54mm nut.
Torque the nut to 59NM
Turn the hub left and right a few times.
Then loosen the nut until the nut can be turned by hand.
Then tighten the nut again to 59NM.
Then again loosen it until the nut can be turned by hand.
Now your ready to torque the nut to 5.4NM, which is quite low and a lot of gauges dont go that low.
This is the gauge I use.
Now as youve noticed the gauge doesnt go low enough.
So what I do is I wind the torque wrench until its sitting at the lowest mark. In my case 30NM.
I then wind it back from 30NM, 10NM which would obviously be 20NM, then another 10NM till I get to 10NM.
I then wind back until I get to what is effectively 5.4NM. (pic shows 4.5NM.
but you get the idea.)
That method always works well for me, and when I then add the lock washer and torque the other nut up, im normally some where near right with the fish scale.
Sometimes I do have to take the second nut and lock washer back off and slacken the first nut off slightly to get it right on the fish scale, but not always.
Personally I find front hubs/axles such a messy job, I'd rather do it exactly to the FSM and then hopefully I wont have to do it again for a while.
Sorry cant help with your brake pipe issue.
