Hello land cruiser friends!
I have an awesome 80 series Manual, Diesel build in 93
I have a problem on the front left wheel. It leaks grease and I can’t find where exactly. It seems to be between brake disc and knuckle (joint/hub sorry don’t know what its called) its not between axle and joint.
My questions:
1 How urgently do I need to fix it? I put every few thousand km some new grease in. and I would like to go on a 4wheel drive trip over Easter approximately 1000km do I need to fix it before?
2 How long does it take to replace all bearings and seals including axle oil seal? (for a professional mechanic and how long for let’s say for a hobby mechanic)
3 I have seen few bearing, knuckle sealing kits online for about $130 are they OK or should I get original parts from Toyota? Can someone recommend something?
4 Do I need to do a wheel alignment after the rebuild?
Your help is much appreciated
And another question how bad is it if your wheel bearings are loos (mine are fine I just want to know it)? What could worst case happen?
Thanks again!
I am looking forward to fix my beauty
Karl
My questions:
Thanks again!
Karl
