Problem with front cabin heater
Hello all,
My '92 HDJ80 doesn't have heat coming out of the dashboard and I don't know
where to look for after I did/observed the following:
- Manual valve (on firewall in engine compartment) is fully opened.
- Heat is coming out of rear heater full blast.
- In-dash fan is working properly
- Coolant level is good.
- In engine compartment, I unplugged the hoses going to and coming from the
front cabin heater and ran a flow of water through it => nothing came out
(rust, goo, shit, ...) and the flow ran very well, hence the heater core is
not plugged.
The Shop manual refers to a "heater relay" but I don't know what this relay
is supposed to do nor where it is located. At first I guessed it was a relay
used to regulate the heat in automatic A/C-Heater systems, but the shop
manual refers to it in its NON-automatic A/C-Heater system chapter...
Any advice/idea welcome.
I hate driving with a warm ass and cold nose (need to run the front
ventilation for defogg) :o))
Thanks on advance,
Lio
The only thing that I can suggest is an air lock, or a small amount of
dirt. I had a Range Rover once and washed out the heater matrix and it
was still bad. some months later I had to remove the unit. While it
was out I washed it and got the smallest amount of dirt out, when I
put it back it was excellent.
Regards, Clive.
On 12/1/05, HEBERT Lionel <[Email address removed]> wrote:
ow
he
ut
is
ay
lay
spondance privee et confidentielle a l'attention exclusive du destinataire designe ci-dessus. Si vous n'etes pas le destinataire du present message ou une personne susceptible de pouvoir le lui delivrer, il vous est signifie que toute divulgation, distribution ou copie de cette transmission est strictement interdite. Si vous avez recu ce message par erreur, nous vous remercions d'en informer l'expediteur par telephone ou de lui retourner le present message, puis d'effacer immediatement ce message de votre systeme.
only for use of the individual or entity named above. If you are not the intended recipient or the agent responsible for delivering the message to the intended recipient, you are hereby notified that any disclosure, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify the sender by phone or by replying this message, and then delete this message from your system.
Lio
<Clive wrote>
| amount of dirt. I had a Range Rover once and washed out the
| heater matrix and it was still bad. some months later I had
| to remove the unit. While it was out I washed it and got the
| smallest amount of dirt out, when I put it back it was excellent.
Looking at the Haynes manual it seems to suggest that the rear heater is
teed off from the main heater feed somewhere inside the firewall. If
this is the case maybe your flushing water all went through the rear
heater and, if Clive is right, a more vigorous flush (perhaps in the
other direction) might shift something. But it's a pretty vague diagram,
so it may be misleading and you may indeed have flushed the front matrix
only.
<Lio wrote>
| this relay is supposed to do nor where it is located. At first I
| guessed it was a relay used to regulate the heat in automatic
| A/C-Heater systems, but the shop manual refers to it in its NON-
The Haynes wiring diagram, which is not for the version with climate
control, shows the main "heater relay" as feeding everything including
the fan. This seems to tie in with your manual and suggests that if the
fan is working the relay is OK.
The only other thing I can suggest before you start tearing it apart is
a good search in the 80sCool archive
http://www.birfield.com/modules.php?name=3DArchives&p=3D/archives/html/80sco
ol/
Sorry, probably not much help.
Christopher Bell
Devon, UK
1996 1HD-FT
Are you sure the hoses you put water through are the right ones? I'm
only asking because last time I looked at those hoses the flow wasn't
how I expected till I looked a bit closer.
Best regards,
Jon.
-----Original Message-----
On Behalf Of HEBERT Lionel
Sent: 01 December 2005 09:06
To: elco
Subject: [ELCO] Problem with front cabin heater
Hello all,
know
the
out
is
not plugged.
relay
relay
Thanks on advance,
Lio
heater
=> Yes I did see the connecting hoses and I made sure the water I was
flushing in didn't go into the rear heater but through the front on.
=> That's some good news! thanks for the hint.
During a talk with Denis last night, he suggested looking at a possible
failed flap in the dashboard, keeping the air from going through my heater
core. I didn't find anything about this in the shop manual (Thanks again
Jon W.!) but will look again.
Thanks for your advice and suggestions folks!
Lio
heater
Lio
heater
Lio
=> Humm, you get me doubting now. It seemed obvious when I did it as there's
a flow direction arrow on one of the hoses and one can clearly see the hoses
going through the firewall to the front heater core and the ones going down
along the firewall to the rear heater core... I will check again.
Thanks,
Lio
Hi Lio,
Out of interest, is the actual fan working, you haven't said?
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
Hi Lio,
Subject: Re: [ELCO] From: Julian Voelcker <[Email address removed]>
=> Hi Julian,
Yes, Fan is working properly at all speeds and I can choose the direction of
the flow (windshield, face, feet, ...).
Basically, I stopped having hot air comin from the dashboard one day without
knowing why, without anything else failing, without me touching or taking
apart anything...
Thanks for your interest.
Work days are too long for me to do anything on the truck at night. I will
try to look at the whole system again this week end, especially that flap
Denis talked about (possibly keep the air from going through the heater
core), and will give you an update nexe week.
In the mean time, keep the questions and suggestions coming!
Cheers,
Lio
I had a similar problem when I bought my Truck....The problem was the
water diverter valve on the fire wall inside the engine bay.
=> Hi Tiaan,
Thanks for the suggestion but I already checked that valve and it's working
properly as the rear heater blow hot air in demand.
Lio
