1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Pulling to left side when braking
Rob Johnson Feb 16, 2011
  1. Rob Johnson
    Rob Johnson New Member
    34
    0
    16
    Hi Folks,
    My Prado has started to pull to the left under braking, the steering wheel actually rotates as you brake. My local garage has had a quick look for any play in anything and all they came up with was that the steering rack had a tiny bit of play (then quoted £1900 for a new rack from Toyota!!!).
    I have a feeling it is something less serious, any ideas? It is in getting the braking effort checked today as a friend has just told me he noticed a little bit of steam coming fom that area when coming out of water when we were 'laneing at the weekend so I thought maybe the brake was stuck on a little!
    Any Ideas would be gratefully received.
    Cheers :character-beavisbutthead:
    Rob
  2. Chris
    Chris Super Moderator Supporter I am in europe
    13,107
    836
    113
    Garage:
    Map
    Sounds as though your right caliper simply isn't working properly. I'd say that needed a new rack is complete tosh and anyway the bushes are only £50 on their own. If this came on suddenly, I go for one caliper not applying properly. If the vehicle grabs left, then the left caliper is working and it's the right not pulling its weight. Simple strip, clean and work the pistons in and out to start with. Pretty common. You might need a bigger service, but just check piston movement to start with.
  3. Rob Johnson
    34
    0
    16
    Thanks for that Chris,
    Seems to make sense, and would explain why the left hand brake was steaming, as I guess it would be doing the work for the other!
    I'll see what they come back with today!!
  4. Graham
    Graham Well-Known Member I am in uk
    3,804
    48
    48
    Garage:
    Map
    £1,900, :o
    They are taking you for a fool.
    You have all the knowledge right here on the forum.
    There are guys here, like Chris, and Jon, and Ian, that know more than the Toyota tech's.
    Could well be the right caliper just isn't doing it's fair share of work.
    The number of peop's who have stuck calipers because of laneing, is fairly common.
    If the worst, then a pair of front reconditioned calipers could be an option, depending on what the brake bias chats look like after brake tests.
    Like Chris has said, spending £1,900 on a rack is so far down the list, it just isn't worth tinking about.
    Graham
  5. BIG clean GREEN
    BIG clean GREEN Well-Known Member
    949
    2
    36
    Garage:
    Map
    Our very own Mr Rubie does the caliper seal kits for a few quid, fairly straight forward job if you need to replace them, but do as Chris has advised first, then you'll see if you need the kit or not ! Also do a search in the forum for brake caliper or brake seals Etc. for more info !
    Nick.
Share This Page
