MisterCruiser
- May 28, 2014
My 120 pulls to the left under braking. I remember hearing that if it's a caliper at fault, the faulty caliper is usually the one that is the opposite side of the diving. Did I hear this correct, or is it actually the other way around that whichever side it pulls to it's that same side caliper.
Thing is I have had the drivers side caliper off now when removing the driveshaft to replace the CV boot and the calipers pistons on this drivers side caliper are fine.
I put new pads and discs all round on it last Summer and the calipers were fine then so I don't think the passenger front is sticking either but I'll open it up and check anyway when I get time.
I'm currently also replacing the drivers side front wheel bearing, it's very noisy when driving, dry bearing, but no play in the wheel so I don't think the wheel bearing is the cause of the pulling to the left.
I can't drive it at min as can't put the new wheel bearing back on yet as waiting on a steering knuckle seal to arrive.
Bushings seem ok, what else can cause this?
