Towpack
Anyone know if this tool inj pump timing tool will fit the pump on the 80?
The tool in the ad is the right approach. You'll need a dial gauge to fit to it. Also the pipes coming off the pump may get in the way so you may have to remove them. The Toyota tool has a see saw arrangement to get the dial gauge away from the pipes so you don't have to take them off.
How much is the toyota sst tp?Thanks Frank.
I already have a couple of dial gauges so hopefully one will be suitable. The OEM Toyota SST isn't cheap so, even if I have to buy another gauge,it'll still work out much cheaper.
The FSM does show the removal of a couple of the injector pipe unions to facilitate access.
I'm having another go at locating the sound of the intermittent engine tick/tap. I don't really think it's a timing issue but I've ruled out the most obvious possibilities so I'll try anything. I also have a new OP relief valve and spring as they have been mentioned. Again an unlikely culprit but the parts were cheap (under £10) so I'll fit them.
Any thoughts on the link?
