Just stumbled across this. I have a similar noise on mine. From about 45mph the noise is noticeable and as you say Chris you can play a tune. Mine seems particularly loud between 50mph and 65mph and as soon as you lift off the power the noise stops.
I had a seperate problem with my autobox last year (it basically lost drive) so it was removed and inspected by a gearbox specialist and it was declared to be in perfect condition. The problem was then thought to be the transfer box so this was swapped but it turns out this was not the sole cause of the problem, a faulty 1st gear solenoid and corroded wiring for the selector sensor also had their part to play. Once these were replaced, autobox works perfectly.
But the whine Chris describes was there before and after the gearbox problem.
Then the bearing in the front diff (crown pinion?) went. I took the front prop off, engaged the CDL and drove it somewhere to be get the diff sorted. I would swear that the noise had disappeared.
Got the truck back with repaired front diff. The noise is back. So in my case the whine doesn't appear to be a gearbox problem, a transfer box problem or a front diff problem. When the weather is warmer I will take the front prop off again to see if the whine disappears. With my lack of technical knowledge and capabilitiy I'm not entirely sure what that will prove but armed with the information I will get my garage to ponder it.
Steve
Steve
