The ride is great, very comfortable although i was not sure my AHC was working correctly. It went up and down on the buttons and always seemed to ride level even after jacking up after it had levelled itself. As i said, the adjustable link arms on the height sensors were not in the best of condition and the rear one was pivoting by rotating the mounting ball joint in the body bracket. The sport/comfy settings did make a difference.
With ride though, nice and comfy. The steering wobble has gone but that might be to do with angle of the track rods biasing the mounting of the steering rack, i will still be replacing the bushes but i am sure the steering is a little sharper than before.
The CV's are at a greater angle so will research the diff drop, in the meantime i will replace the CV boots and regrease the shafts, good chance for a proper wheel and spindle bearing inspection too.
The tyres have now settled down but noticed a cut nearly all the way around on the bead on one, if not a manufacturing fault then must have been done on mounting the tyres, only done about 500 - 1000 miles on them and all on tarmac.
