LeCruiser
Had a leak on the front of the diff which is more than just a seal and a fair bit of play. Took diff out yesterday and it's clean with no metal bits, crown and pinion seem fine.
it looks like the front pinion bearing is foo barred, can't tell until I press it out but 99% sure it's that.
Question is.... Do I just to that bearing whilst the diff is out or replace all 4 bearings in the diff? Anything else I should do?
Or go half way and just do the 2 pinion bearings?
if it's front bearing only guess that's from Toyota as Milners don't seem to do one
thanks
thanks
