Got a replacement rear locker from Karl (thanks again!)
Works fine, fitting went well.
Tried to engage it yesterday whilst out in the woods, and no amount of left or right turns would get it to engage, which prevented some of the more extreme things i wanted to do. I did a full circle on loose gravel clockwise and counter clockwise. I can hear the locker motor running so presume its more to do with what happens next inside the diff. light was still flashing and rear wheels were not locked.
Am planning on popping off the switch on the front of the diff that checks for the position of the actuator to see if we have any movement and the switch is faulty (presume 3 or 3 wheels off the ground for that test.
Was wondering if anyone has any ideas as to what might be happening, or not happening, what i should also check for.
thanks all.
thanks all.
