Hi folks,
I just introduced myself to the forum over on the introductions thread.http://landcruiserclub.net/forums/showthread.php/56801-Hi-folks-I-m-Justin
My land cruisers is having some rear door trouble, specifically the hinge that limits the distance that the door may open has ripped out of the door itself on the driver's side. I see fatigue cracks forming on the passenger side rear door as well. This is a 2000, so 15 years of kids throwing doors open with wild abandon have taken their toll I suppose. I'm not 100% sure what I want to do about this. I've got a $700 quote from a body shop that will take doors off, sand and trim bad metal, weld in reinforcing bar onto door itself and then replace and reattach the door range limiter (not sure the precise term for this piece - if anyone can define, I'll start using the right term). Then, they will tac-weld the fatigue lines in the passenger door frame, and then repaint.
It sounds like the best option short of replacing the doors, which is what another body shop said was necessary for the $2k US.
Here's where you all come in, which path would you take on a truck with 210k miles on it? Any opinion is welcomed.First Photo is of the driver side rear door that has already pulled out - quite a bit worse now after not dealing with it for months. the second photo is of the passenger side rear door where there is fatigue cracking and will be easier to deal with.
thanks!
p.s. is it forum etiquette to post pictures this way or as attachments?
thanks!
