warrenpfo
- Jul 21, 2010
After just going to the car to try and pinpoint a squeak I ended up removing the glass in 5min.
It's a very easy job should you want to do it.
With the roof tilted up pry the side moldings on the glass off with a scraper.
With the plastic removed you will see 3 M10 bolts on each side that need to be undone.
Having removed them you will notice some spacers between the glass and the frame. I assume they are the same on all cruisers but might not be so note there orientation and numbers. I had two on the front and one on the rear.
The glass just lifts off having undone the bolts and you can then nice the seal a good clean and or replace if you need to.
Just reverse to install
