Guys, noticed yesterday and confirmed by Carl, Milner have full replacement wiper linkages in stock. We all know that they go a bit loppy. It's usually the liners in the turrets that wear out and then the alloy casting starts to wear away and then the spindle goes all 'Wobbly Bob' on you. They are £80 + vat. Getting the old ones out is easy enough, but the bolts holding them in 3x 6mm in each, just snap off. So you'll need some new bolts. But your wipers will be like new ones. I have good turrets, but the plastic liner inside has worn away inside and the spindles sort of weather vane around inside making the wipers skip sometimes.
Now - the left and right turrets are interchangeable and the linkages are generally fine, so you you could split a set with a mate and simply have a new turret each. I don't know why, but it's usually the driver's side that goes. £40 plus vat to fix your busted wipers?
No I don't have shares in Milner (and they have their faults) but spreading the word on essential bits like this is what the forum is for.
