Replacement headlights
karl2000
The problem is once you start sanding them, the final coating you spray on there to protect them isn't as good as the factory finish you've sanded off, so you have to keep doing it. Seems you have to keep doing it more and more often to keep them looking good - that's what I found anyway....
I like the sound of replacement lenses - didn't know they were available!
Gary Watson
australia
on a 100 series the depo lights go straight in and the adjuster motors fit in perfectly no problems at all could not say for the 120 series but for the 100 series 2006 model Sahara they go straight in
Tractionman
Thanks Tony.
With my luck the whole bleedin lot would melt in the oven.
I notice it says they are glass ? Mebbe something lost in translation there.
Anyhoo thanks for the info mate, always good to have options.
Juddian
Well, an update.
I splashed out on the 3M headlight polishing kit and have just spent an hour and half polishing the lenses up, previously have always used metal polish but probably not abrasive enough.
Its a bit worrying after using the first cut with 500grade on the electric drill, completely opaque finish, but very pleased with the results afterwards.
With the headlights on you can still see the crazing deep in the lens where presumably heat from the bulbs has caused crazing too deep inside the lens to actually polish, but nowhere near as cloudy finsih generally.
Have used a glass sealer on them and two coats of Bilt Hamber's wax, have ordered some CarPlan No1 Gloss from Amazon on the recommendation of TonyCL on t'other forum.
Hopefully the pics before and after will add to this
Not being David Bailey the pics aint great but hopefully show the improvement, if anyone asks which was the before/after pics i'll go boil my head.
As a bonus for those who like them here's two of our idiot doggies
