OK, not being lazy and I will look at the wring diagrams etc, but worth a shot if there has been something similar before.
Got some minor issues with the truck, most are just a quick fix, but oddly the fuel gauge doesn't work. Filled with cans today - nothing. The oil pressure gauge is off the scale - always. Even with no batteries connected and I'm not sure that the temp sender works either. Pulled gauge fuse and the volts stopped immediately. Put it back in, working again. Not the fuse then. It almost feels as though one of the multi plugs isn't pushed in right. Hmm? Rev counter and speedo work.
Anything blindingly obvious boys?
Oh, poured water into the sunroof surround today. Poured out of the driver side. Nothing at the passenger side. Shoved some welding wire in there and it ran for TWENTY MINUTES!!!!
Ahh, that would either be blocked and full in the sill or I have aux ballast tanks fitted! Is there only one drain per side? This might explain the damp foot well.
