I had some new 265/75/16 Grabbers fitted this morning which I am over the moon with. On tar they are much better than the road oriented mix of hoops that were on there before, giving a much smoother ride and the steering is a lot less vague than before - previously I found myself subconsciously braking for every little bend in the road, now it just rails around corners like it should.
The spare wheel cover however won't go over the new spare because the tyre sits right up against the body work - is there a spacer than I can fit to raise the tyre about 5mm off the body so that the cover can tuck in behind it?
