The sunroof on my 80 developed the usual leaking syndrome that seems to affect many.
My drive has a very, and I mean very, slight slope so the car sits 'nose down' by an inch at most. I have cleared out both front sunroof drains with a piece of fairly stiff electrical wire. With the sunroof open if I poor water in the channel if drains straight away through the drain holes.
But, I am still getting wet carpets. It is definitely the sunroof it is coming from as the 'A' pillars are damp
As the sunroof is never opened my plan of action is possibly going to be a piece of vinyl wrap to cover the front of the roof including the sunroof.
Anyone else tried something similar? My only concern is the slight movement of the sunroof my end up tearing/cracking the vinyl in time![]()
I found this out earlier todayThat stuff is only really any good if all of it is in full contact with steel....
I guess my plan at this stage was to find out if it is indeed the sunroof or the windscreen that was causing the issue.Going back to the OP, if the front drains are actually taking water away but the A pillars are getting wet it sounds to me like the drain tubes could possibly be split or ruptured?
So is it screen to rubber or rubber to body that leaks Jon, or both?You might be as well to pop the windscreen out and reseal it anyway Paul, it will start leaking at some point even if it isn't now....
That is certainly one of the places mine is leaking. When driving in torrential rain I have to hold a cloth/sponge/paper towel there as it runs through and drips straight onto the electric window switchesI also had a leaking A pillar. Water came thru the handle to pull you up at the drivers side.....
I had my windscreen replaced in December and the chap came all the way from Inverness (5 hour round trip) and despite phoning first and confirming the type of rubber (oo errr Mrs) he still came with the wrong sort (the new one was slotted for a chrome strip). So the old one was reused. about 6" of water in the footwells this morning (parked on a slope). So looks like he's gonna have to do it again with another 5 hour round trip !The rubber is a pinch seal onto the lip round the windscreen opening, similar to the rear tailgate seal, and then the glass sits inside that rubber with sealant round it. I don't know stats for which leaks most but Rob's had some rust around the windscreen pinch weld indicating some leakage there but as the screen was also loose in the rubber that was probably the main problem! My green one leaked profusely between the rubber and body. I'd change the rubber rather than reuse the old one, less chance of a wasted job ...
But where ? !!!!!!!!
