what should be the level of the fluid in position low, N and high? is it normal when is on High the level is below minimum ?
The level in the reservoir should
only be checked with the suspension in the 'N' postion,
Not L and Not H.
The fluid level with Suspension in postion 'N' should between 'Max' and 'Min' in the reservoir, do
NOT use any other AHC fluid, or any other fluid other than the genuine Toyota AHC fluid PN 0888681260, this is very, very important, otherwise
in the long run you'll end up with a whole host of problem's.
So,Yes, when your AHC is in 'H' it is normal for the level in the reservoir to be below minimum, just as when it's in 'L' it will read above 'Max'.
When you lower the AHC, fluid is pushed into the reservoir, when you raise the AHC, fluid is withdrawn from the reservoir, obviously this all has to be done with the motor running and all the door's closed, bonnet/ hood can be open.
All of the above is presuming your AHC is in good operating condition, I.E no leaks and no wear in the Spheres.
Hope this helps.
