Thanks Andrew, it was on my list of places to check, just can't do it at work.... The door is from a newer vehicle, but I doubt that they would change that...... would theyAndrew Prince said:Doing your legwork for you on ToyoDIY it looks like the doors are the same. It seems that there were some changes over time but I think these were mostly cosmetic as best I can tell from the diagrams. Ideally if the donor vehicle and yours were the same age, then there should be no issues at all.
You may need to swap a lot of the internals, panels etc but the basic steel should be identical.
Cheers,
Well you could always measure Fierys just for a laughsae70 said:LOL I was going to offer to go out & measure Fierys door for you so you could compare to a measurment taken by someone else from off of a 95 but then I realised that you already know how long a 90 door is
Thanks, so I just need to decide if it's worth fixing something that I will inevitable dent againignat said:Looked on ToyoDIY and looks to me the part numbers are the same.
TonyP said:Does anyone know if the door from a LWB 90 will fit a SWB? I'm guessing not, but you never know....
