Hi
A couple of gadgets i have fitted to my 200 series.
1 a tpms EK2 Brand.
EH215H TPMS
It is a Tpms that monitors your tyre pressures and temperatures whilst in motion and will alarm when preset temperatures or pressures both High or Low are exceeded showing you which tyre has the fault.
Each tyre has a transmitter fitted to the valve stem.
The system can take up to 22 wheels and also can link or unlink a set of trailer or Caravan wheels.
This system was designed for Semi trailers and so far it seems quite good and reliable offroad.
The other Gadget is the Scangauge II.
This gadget connects to the vehicles computer via the diagnostics port. It has trip computers built in to monitor. Tank to empty ,How much fuel used. Auto transmission temps which also help identify when torque converter is locked up which gives better economy. It can also clear error codes when logged to help the vehicle out of a tight spot till back to dealership. It has alot of helpful features.
Beno
1 a tpms EK2 Brand.
EH215H TPMS
Beno
