One for Niall others might have some input?
Was looking at the thinkauto site (they make the mocal range) and found
these. If you stick with an auto what would your thoughts on these oil
coolers be? (also used for transmission fluid)
http://www.thinkauto.com/laminova.htm
I am thinking the coolant to oil will give a more stable transmission fluid
temp in high air temps with poor airflow, perhaps even warm the fluid in the
winter. They look like an fairly easy install, don't need to be mounted in
air flow and don't get blocked with mud.
Malcolm
Stafford (UK)
FJ45 '75 & FJ45 '76
Malcolm
Stafford (UK)
FJ45 '75 & FJ45 '76
