MisterCruiser
- May 28, 2014
So, I'm considering buying a 120 cruiser that has a blown turbo and 300k miles on it. It's one of the early models with the 5speed gear box, etc..
I haven't looked at the vehicle yet but just looking for some pointers to determine the health of the engine, I don't want to buy it if the engine is blown too.
He says it's smokey when driving, not too bad when idleing and low power.
I can do the trubo work myself, my plan would be to replace turbo obviously and cremove and clean the EGR and Manifold too.
And remove the sump and clean the pick up too.
I don't know why the trubo failed yet so there could be an under-lying fault I don't know of other than wear and tear.
Any tips for checking the engine, I don't want to drive it too much with the turbo gone, if I remove the oil cap will that reveal anything, if it's pumping out fumes / gases under pressure I believe this can indicate a cracked piston on landcruisers. What should removing the cap on a healthy engine do?
Obviously I can listen for any unhealthy sounding noises coming from the engine etc.,,, but can anyone suggest anything else I can check when looking it over?
Also, would 300k miles put most people off this vehicle regardless of a blown turbo?
