Ok so I have been watching quite a bit of You Tube this week looking at splicing and winching, all in connection with my new winch ropes. What I noticed throughout was the way the presenters set the lines and the use of the shackle when connecting up the whole rig. I have never heard nor had a discussion about this so I thought I'd start one.
Here is what almost all of them do.
My view is that this is not only not the way, but it's actually the WRONG way. Feel free to start a fight. The strap is fine, but the hook is placing all of the load in one small area on the pin. It can and will slide from side to side under load and damage the pin. Any damage or distortion to the pin makes getting it apart very difficult and may render the item scrap. I have never set shackles like this. If the load is significant, it can also sprain your shackle if it pulls against the pin holes. As we all know, you undo your pin a half turn or so to prevent it jamming. Well this actually allows the frame of the shackle to sprain into that gap.
I do them like this -
OK it's the wrong sized strap yada yada - oh and it's not connected to a winch either but you get the idea. The softer strap is now spreading the load across the pin and won't move under load. The hook will now self centre in the bow. If it wants to move laterally, it can, but it's not going to cause damage to the vital bit, the pin. Now, sometimes your hook won't slip over the pin and I see people taking the pin out and putting it back through the middle of the hook. So, if you can't get the pin out because you have damaged it, how you gonna get your hook off?
So someone convince me that the other way around is better?
Or do I need to get out more.
More excellent tips from the winching channel soon.
