- Feb 24, 2010
This goes for everyone:seems that I've dropped off the map How do I get back on?
I've created a new profile field for everyone called Map Location and copied what you have in Location across to it. I use Map Location to display you on the map. About 100 people have a humourous location entered like yours, "sunny Anglesey" When I give that to Google, it tells me to sod off as it is not valid.
So, if you can edit your profile (Settings, top right of screen) and enter something that a sat nav would understand. It does not have to be your exact address (bad?) but the town, area of the town etc and country. If you then wait about an hour, you should see yourself popup.
Can I have a snippet then on how to shift latitude by n meters? Is it a straight multiplication of something or more?I think that should be a good compromise.
