Hi to all you out there.
I have just become a member to let you all know what i intend doing on the Sumobars for the Land Cruiser 80 series for now, i do actually own a 80 series as well and have had Toyotas for many yesrs, i mainly do Land Rover items and i baught the rights for Sumobars just over 12 monts ago, we curently do all the Land Rover Sumobars and the new Ultra Extreme Sumobars, thats when i thaught why not do some for the Land Cruiser as well, i had to fit a track rod end to a customers Land Cruiser and the thread was not good in the track rod bar, toyota dealer wanted about £100.00 just for the bar without track rod ends, so i thaught about geting some made, the standard bars are hollow and not a very thick wall on the tube, they are fine for normall use, but as these are used for off road i think a heavy duty bar is required, if you do bend a standard one yes it can be straightned, but tube is hard to get straight again and if you do get a kink in the bar you will have a weak spot, i have seen this on standard Land Rover ones and they eventually brake as they try to flex on the kink, i know they are more out of the way on the Land Cruiser compared to a Land Rover track rod, but it is the side impact that causes them to bend, especially if you have a slight bend in them to start with, the problem with the Toyota bars is they have 2 diferent threads M23 on the track rod and M21 on the front drag link, these are not a standard tread, thats why the tooling cost will be very expensive, thats why i contactet Paul to see if there would be much interest in the Sumobars for the 80 series.
I will be looking at doing them out of 35mm solid bar, the same as our Ultra Extreme Sumobars, i know you have all seen the prices of the Land Rover ones but it is a totaly diferent thing, i get 100 Land Rover ones in one order and i know they will sell.
The price would probably be about £80.00 per bar and you can use your standard track rod ends in them, the steering damper is not a problem as it ataches to the one track rod end nearest to the steering box.
I have been surching to se if anyone else does bars for these but havent found anyone out there.
I will keep you all informed on what i will be doing on them.
Thanks.
Gwyn Lewis SUMOBARS.co.uk
